[GRASS-dev] epsg code stored anywhere and used by v.out.ogr/r.out.gdal?
Markus Neteler neteler at osgeo.org
Sun Nov 16 00:58:15 PST 2014
On Nov 16, 2014 9:37 AM, "Helmut Kudrnovsky" <hellik at web.de> wrote:
> Hi,
> if the location is created by an epsg code, is the epsg code stored
anywhere
> in the location?
It is sometimes stored in the PROJ_INFO file.
> if yes can be the epsg-code-representation of the projection used by
> v.out.ogr/r.out.gdal instead of the grass gis representation of the
> projection?
Often not since it may lack datum parameters.
Markus
> best regards
> Helmut
http://osgeo-org.1560.x6.nabble.com/epsg-code-stored-anywhere-and-used-by-v-out-ogr-r-out-gdal-tp5173171.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141116/ef3c3bc4/attachment.html>
