[GRASS-dev] Tests down to 65% (from 86%)
Vaclav Petras
wenzeslaus at gmail.com
Sun Nov 16 18:54:31 PST 2014
Hi all,
something happened between r62745 (Saturday) and r62754 (Sunday) because
tests are failing. Here are the changes in trunk:
http://trac.osgeo.org/grass/log/grass/trunk?action=stop_on_copy&mode=stop_on_copy&rev=62754&stop_rev=62746&limit=100&verbose=on
MarkusM, I'm not sure what was the actual change but it seems that
G_tokenize() is the only related change. From the tests it seems that
something in parser is failing.
I've also noticed that the documentation on server does not contain
generated/standard flags (--), the flags are included when there is a short
flag (-). I get the flags on my local machine with recent version. Was this
changed somehow lately?
Vaclav
http://grass.osgeo.org/grass71/manuals/r.rgb.html
http://grass.osgeo.org/grass71/manuals/r.blend.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141116/6daec402/attachment.html>
