[GRASS-dev] Tests down to 65% (from 86%)
Markus Metz
markus.metz.giswork at gmail.com
Mon Nov 17 02:32:31 PST 2014
On Mon, Nov 17, 2014 at 3:54 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi all,
> something happened between r62745 (Saturday) and r62754 (Sunday) because
> tests are failing. Here are the changes in trunk:
> http://trac.osgeo.org/grass/log/grass/trunk?action=stop_on_copy&mode=stop_on_copy&rev=62754&stop_rev=62746&limit=100&verbose=on
> MarkusM, I'm not sure what was the actual change but it seems that
> G_tokenize() is the only related change. From the tests it seems that
> something in parser is failing.
G_tokenize() no longer removes leading spaces (it never removed
trailing spaces), but G_parser() relied on that. G_tokenize()
tokenizes a string, spaces can be removed with G_chop(), G_squeeze(),
or G_strip(). Fixed in r62763,4.
BTW, the test suite does not run with Python 2.6 because import
argparse fails, this module is new in Python 2.7.
Markus M
> I've also noticed that the documentation on server does not contain
> generated/standard flags (--), the flags are included when there is a short
> flag (-). I get the flags on my local machine with recent version. Was this
> changed somehow lately?
> Vaclav
> http://grass.osgeo.org/grass71/manuals/r.rgb.html
> http://grass.osgeo.org/grass71/manuals/r.blend.html
