[GRASS-dev] How to calculate log() in v.db.update with SQLite backend?
Moritz Lennert
mlennert at club.worldonline.be
Thu Nov 20 00:22:58 PST 2014
On 20/11/14 08:46, Moritz Lennert wrote:
> On 19/11/14 19:12, Vaclav Petras wrote:
>> On Wed, Nov 19, 2014 at 12:59 PM, Markus Neteler <neteler at osgeo.org
>> <mailto:neteler at osgeo.org>> wrote:
>> DBMI-SQLite driver error:
>> Error in sqlite3_step():
>> not authorized
>> ERROR: Error while executing: 'SELECT
>> load_extension('/home/neteler/software/sqlite_extensions/libsqlitefunctions.so')'
>> Traceback (most recent call last):
>> Process ended with non-zero return code 1. See errors in the (error)
>> output.
>> No idea what's disliked here in:
>> SELECT
>> load_extension('/home/neteler/software/sqlite_extensions/libsqlitefunctions.so');
>> UPDATE meuse_voronoi SET logzinc=log(zinc);
>> Any hints?
>> Loading user defined function is not considered completely safe, so it
>> is disabled by default. I think this is not an issue for GRASS GIS.
>> You have to enable it somehow. It seems that enable_load_extension() is
>> the way.
> Right.
> But this depends on the installation, i.e. how sqlite3 was compiled.
> Here in Debian Testing I do not need to activate anything, so I assume
> that it's activated by default.
However, I'm not sure if sqlite needs to be compiled with this option by
default. I think we could activate it in the sqlite driver.
Below is a proposal after a very superficial reading of the docs and
code, so no guarantees (and I cannot really test here since it seems
enabled by default).
However, this means that we enable this automatically for each sqlite db
opened by GRASS...
Moritz
Index: db/drivers/sqlite/db.c
--- db/drivers/sqlite/db.c (révision 62792)
+++ db/drivers/sqlite/db.c (copie de travail)
@@ -110,6 +110,9 @@
return DB_FAILED;
+ /* enable loading of extensions */
+ sqlite3_enable_load_extension(sqlite, 1);
/* set the sqlite busy handler */
sqlite3_busy_handler(sqlite, sqlite_busy_callback, NULL);
