[GRASS-dev] Issues installing GRASS 7.0 from Ubuntu PPA
Isaac Ullah
isaac.ullah at asu.edu
Thu Nov 20 08:37:25 PST 2014
Vaclav,
Thank you for your response, it is very helpful! So, the upshot is that
the current version packaged for Ubuntu in the PPA has the broken
g.version, which somehow prevents the GUI from rendering. This is just in
the PPA version, but the compiled version *should* be fine. So my current
options are to roll back to an earlier version, compile the current version
from source, or to run GRASS headless for the moment (no issue for me)
until the problem is fixed (I assume at least by when 7.0 stable is
released?).
Also, thanks for letting me know about g.mremove. I didn't know about that!
I am currently porting some of my addon modules to 7, so I will change
their map clean up routines to use the new functionality of g.remove. Goes
to show that I ought to pay more attention to the roadmap!
~Isaac
On Wed, Nov 19, 2014 at 7:52 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Wed, Nov 19, 2014 at 7:36 PM, Isaac Ullah <isaac.ullah at asu.edu> wrote:
>> Sorry, premature send! Here's the error message:
>> Launching <wxpython> GUI in the background, please wait...
>> [Raster MASK present]
>> GRASS 7.0.0 (Exp3):~ > Traceback (most recent call last):
>> File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 140, in <module>
>> sys.exit(main())
>> File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 133, in main
>> app = GMApp(workspaceFile)
>> File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 48, in __init__
>> wx.App.__init__(self, False)
>> File
>> "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line
>> 7981, in __init__
>> self._BootstrapApp()
>> File
>> 7555, in _BootstrapApp
>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
>> File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 82, in OnInit
>> workspace = self.workspaceFile)
>> File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 93, in __init__
>> grassVersion = grass.version()['version']
>> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 1467, in
>> version
>> data = parse_command('g.version', flags='rge')
>> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 465, in
>> parse_command
>> res = read_command(*args, **kwargs)
>> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 425, in
>> read_command
>> return handle_errors(returncode, stdout, args, kwargs)
>> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 308, in
>> handle_errors
>> returncode=returncode)
>> grass.exceptions.CalledModuleError: Module run None ['g.version', '-rge']
>> ended with error
>> Process ended with non-zero return code -11. See errors in the (error)
>> output.
> This relates to problems with g.version (#2351) and new, more strict error
> handling (#2326). I tried to fix g.version in r61589 but I'm not sure if I
> was successful, now it seems that I was not. I'm also not sure what r62747
> changed in g.version checks. (Note: Both changes are backported to release
> branch 7.0.)
> At least the error handling now gives us the idea about what's happening.
> -11 means segmentation fault on Ubuntu AFAIK, so it is really related to
> #2351.
> I changed the error handling to "ignore" in r62822 (and backported). It
> reintroduces the original behavior before #2326. Although it might be
> appropriate in this case, the better solution would be to fix g.version as
> r61589 was trying to do.
> https://trac.osgeo.org/grass/ticket/2351
> https://trac.osgeo.org/grass/ticket/2326
> https://trac.osgeo.org/grass/changeset/61589 (
> https://trac.osgeo.org/grass/changeset/61683)
> https://trac.osgeo.org/grass/changeset/62747 (
> https://trac.osgeo.org/grass/changeset/62748)
> https://trac.osgeo.org/grass/changeset/62822 (
> https://trac.osgeo.org/grass/changeset/62823)
>> I still have a GRASS session in the terminal, and can run some grass
>> commands, but not others. For example, "g.region -p" is fine, but
>> "g.mremove" give the following error:
>> g.mremove: command not found
>> Note that g.mremove was recently replaced g.remove. See Trac wiki for
> details:
> https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Renamedmodules
>> The strange thing is that about a month ago, I was able to install a
>> perfectly working version of GRASS7 on a similar computer with no issues
>> (other than the apparently ineffectual error with g.version). I've tried
>> this on three separate computers, and all have the same problem. I've tried
>> installing all the dev packages I could think of (for example, all wx
>> python dev libraries), but nothing seems to help.
>> Any ideas what's going on? What can I do?
>> There is something strange happening with packaging, the self-compiled
> version does not suffer from g.version issues.
> Vaclav
> ~Isaac
>> On Wed, Nov 19, 2014 at 5:30 PM, Isaac Ullah <isaac.ullah at asu.edu> wrote:
>>> Hi all,
>>> I've been trying to get GRASS7 installed on several machines running
>>> Xubuntu 14.04, with no success. These are fresh installs of the OS, so
>>> there should be no cruft complicating install. I'm installing from the
>>> "GRASS-stable" ubuntu PPA repository, and am indeed following all the
>>> procedures. GRASS seems to install okay, but there are major issues when I
>>> try to run it. First, wx-gui dies on start with the following error message:
>>> Isaac I Ullah, Ph.D.
>>> Arizona State University
>>> School of Human Evolution and Social Change
>>> PO Box 2402
>>> Tempe, AZ 85287-2402
>>> (480) 727-1054 office
>>> (650) 201-0479 cell
>>> iullah at asu.edu
>> PO Box 2402
>> (650) 201-0479 cell
>> iullah at asu.edu
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
PO Box 2402
(650) 201-0479 cell
iullah at asu.edu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141120/386dd45a/attachment-0001.html>
