[GRASS-dev] [GRASS-user] wxGUI raster digitizer available
Anna Petrášová
kratochanna at gmail.com
Thu Nov 20 12:12:15 PST 2014
On Thu, Nov 20, 2014 at 3:03 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> While trying to replicate the steps, I found out it worked this time.
> Difference was that last time I edited a very large map so the process got
> probably stuck. Sorry for the false alarm. And again, a great new feature!!
Just let me know if it happens again, it will probably take some time until
we find and fix the bugs.
> On Thu, Nov 20, 2014 at 7:31 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Thu, Nov 20, 2014 at 4:37 AM, Paulo van Breugel <
>> p.vanbreugel at gmail.com> wrote:
>>> Hi Anna
>>> This is great, thanks! This is going to be a real time saver.
>>> I am having trouble however running it. I seems to work fine except that
>>> I can't save the edits. To leave the editing session, I have to select no
>>> when asked to save the work.
>>> Not sure if the below helps, but in the terminal I get the message:
>>> GRASS_INFO_ERROR(30864,1): Raster map <pnv_malawi2_ag2_backupcopy_30725>
>>> not found
>>> GRASS_INFO_END(30864,1)
>>> From the command console:
>>> Exception in thread Thread-8:
>>> Traceback (most recent call last):
>>> File "/usr/lib/python2.7/threading.py", line 810, in
>>> __bootstrap_inner
>>> self.run()
>>> File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/core/gt
>>> hread.py", line 94, in run
>>> ret = vars()['callable'](*args, **kwds)
>>> File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/rdigit/
>>> controller.py", line 467, in _exportRaster
>>> output=self._editedRaster, overwrite=True, quiet=True)
>>> File "/usr/local/grass7/grass-7.1.svn/etc/python/grass/scr
>>> ipt/core.py", line 373, in run_command
>>> return handle_errors(returncode, returncode, args,
>>> kwargs)
>>> ipt/core.py", line 308, in handle_errors
>>> returncode=returncode)
>>> CalledModuleError: Module run None ['r.patch', '--o', '--q',
>>> u'input=x47731795,pnv_malawi2_ag2_backupcopy_30725',
>>> u'output=pnv_malawi2_ag2 at vegetation'] ended with error
>>> Process ended with non-zero return code 1. See errors in the
>>> (error) output.
>> Strange, could you describe the exact steps?
>>> On Wed, Nov 19, 2014 at 11:56 PM, Anna Petrášová <kratochanna at gmail.com>
>>> wrote:
>>>> On Wed, Nov 19, 2014 at 3:31 PM, Markus Neteler <neteler at osgeo.org>
>>>> wrote:
>>>>> Hi Anna,
>>>>> On Tue, Nov 18, 2014 at 5:19 AM, Anna Petrášová <kratochanna at gmail.com>
>>>>> wrote:
>>>>> > Hi all,
>>>>> > I added raster digitizer in r62792 in trunk.
>>>>> what a great job!
>>>>> If you didn't find it: it is in the "Map Display" windows, then
>>>>> selector on the right side (2D/3D/Vector digitizer/Raster digitizer).
>>>> Once everything works, I will probably make a short video tutorial.
>>>>> > You are welcome to test it and
>>>>> > report bugs/enhancements.
>>>>> > It currently allows to draw areas, lines and points and specify
>>>>> width to
>>>>> > buffer individual features. We can discuss some changes in gui
>>>>> interface and
>>>>> > behavior if you find the current one intuitive. There is still a
>>>>> lot to
>>>>> > improve especially in the drawing part (needs some refactoring of
>>>>> the old
>>>>> > drawing code).
>>>>> One general thing I found (also valid for the vector digitizer): I
>>>>> wonder where to put a message what the mouse buttons mean.
>>>>> Maybe in the status bar at bottom of the display/digitizer window?
>>>>> > Features:
>>>>> > - draw area, line, point
>>>>> ... works.
>>>>> > - specify buffer width for individual features to create for example
>>>>> > circles, roads of certain width...
>>>>> ... maybe rename from "Width" to "Buffer width"? Otherwise it could be
>>>>> confused with the drawing line width.
>>>> There is not much space in toolbar..., especially if we in the future
>>>> add more items (settings, label editing for example). What about just
>>>> 'Buffer'? Currently the width is the width of the buffered line/diameter of
>>>> the point (circle), which means 2 x buffer distance, so if we change it to
>>>> buffer, then the value should be half of the line width?
>>>>> > - specify background map
>>>>> ... works (maybe have a button to optionally take computational region
>>>>> from that map?)
>>>> Yes possibly, I am not sure about the region in general, if there
>>>> should be any special handling.
>>>>> > - simple undo
>>>>> > - save button to save results during drawing
>>>>> here I got an issue somewhere:
>>>>> Exception in thread Thread-4:
>>>>> File "/usr/lib64/python2.7/threading.py", line 811, in
>>>>> __bootstrap_inner
>>>>> self.run()
>>>>> File "/home/neteler/software/grass71/dist.x86_64-unknown-
>>>>> linux-gnu/gui/wxpython/core/gthread.py", line 94, in run
>>>>> linux-gnu/gui/wxpython/rdigit/controller.py", line 432, in
>>>>> _exportRaster
>>>>> if item.GetPropertyVal('widthValue') and \
>>>>> linux-gnu/gui/wxpython/mapwin/graphics.py", line 439, in
>>>>> GetPropertyVal
>>>>> raise KeyError(_("Property does not exist: %s") %
>>>>> (propName))
>>>>> KeyError: 'Property does not exist: widthValue'
>>>> it normally works... Does this happen every time?
>>>>> > - keeps drawing order in the output raster map
>>>>> > - change color of drawing
>>>>> > - doesn't block gui when exporting raster (which can take some time)
>>>>> Nice!
>>>>> > Does not support (yet?):
>>>>> > - adding labels
>>>>> > - interactive setting color of raster cells (not planned, there are
>>>>> other tools)
>>>>> > - vector export/import
>>>>> > Known issues:
>>>>> > - r.in.poly supports only CELL (I just realized that, this must be
>>>>> changed)
>>>>> (meanwhile you changed that already, thanks)
>>>>> > - various small drawing issues
>>>>> > - slow when exporting features with buffers (r.grow is slow, probably
>>>>> > because it's a script)
>>>>> Not sure but r.buffer would be appropriate/faster?
>>>> I considered that but the cells grown by r.buffer have different values
>>>> than the original ones, so I would have to reclassify it, so I am not sure
>>>> if it would be faster in the end.
>>>> Thanks for your feedback!
>>>> Anna
>>>>> Markus
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141120/5a9f5e4b/attachment-0001.html>
