[GRASS-dev] [GRASS-SVN] r62845 - in grass/trunk/scripts: . d.shadedmap r.shadedmap
Markus Neteler
neteler at osgeo.org
Fri Nov 21 01:09:01 PST 2014
On Fri, Nov 21, 2014 at 5:00 AM, <svn_grass at osgeo.org> wrote:
> Author: wenzeslaus
> Date: 2014-11-20 20:00:29 -0800 (Thu, 20 Nov 2014)
> New Revision: 62845
> Added:
> grass/trunk/scripts/d.shadedmap/dshadedmap.png
> grass/trunk/scripts/r.shadedmap/
> grass/trunk/scripts/r.shadedmap/r.shadedmap.html
> grass/trunk/scripts/r.shadedmap/r.shadedmap.py
> grass/trunk/scripts/r.shadedmap/rshadedmap.png
> Removed:
> grass/trunk/scripts/r.shadedmap/d.shadedmap.html
> grass/trunk/scripts/r.shadedmap/d.shadedmap.py
> Modified:
> grass/trunk/scripts/Makefile
> grass/trunk/scripts/d.shadedmap/d.shadedmap.html
> grass/trunk/scripts/d.shadedmap/d.shadedmap.py
> grass/trunk/scripts/r.shadedmap/Makefile
> Log:
> d.shadedmap: split into two modules d.shadedmap for display and r.shadedmap for creating raster
> * the raster creation functionality was anyway not sharing any code with the display part in the original d.shadedmap
> * similar things are parameters and manual, so there is now some duplication in this
> * thanks to r.shadedmap, GRASS shading is available to QGIS and others
> * in wxGUI one can create the raster in usual way (before: pressing OK or Apply in d command dialog with no overwrite support)
> * adds also brighten functionality for r.shadedmap implemented according to r.his manual (probably not perfect)
> * changing examples to NC and adding images (different image for each module)
Thanks for your efforts, Vaclav.
But honestly I am not convinced to introduce yet another script
"r.shadedmap" which may add confusion.
At time we have
- d.his
- d.rgb
- d.shadedmap
- r.his
- r.rgb
- r.blend
- r.shaded.relief
new
- r.shadedmap
I see confusion between r.blend and r.shadedmap:
r.blend: Blends color components of two raster maps by a given ratio.
r.shadedmap: Drapes a color raster over an shaded relief or aspect map.
and would suggest to merge both into one script.
thanks
Markus
