[GRASS-dev] Fwd: New Defects reported by Coverity Scan for grass
Markus Neteler neteler at osgeo.org
Tue Nov 25 02:21:44 PST 2014
New stats: 3 new, 16 eliminated...
m.
---------- Forwarded message ----------
Date: Tue, Nov 25, 2014 at 10:58 AM
Subject: New Defects reported by Coverity Scan for grass
To: neteler at osgeo.org
Please find the latest report on new defect(s) introduced to grass
found with Coverity Scan.
3 new defect(s) introduced to grass found with Coverity Scan.
16 defect(s), reported by Coverity Scan earlier, were marked fixed in
the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 3 of 3 defect(s)
** CID 1256093:  Resource leak  (RESOURCE_LEAK)
/vector/v.net/connect.c: 145 in connect_arcs()
** CID 1256092:  Uninitialized pointer read  (UNINIT)
/lib/vector/Vlib/open_pg.c: 803 in read_p_node()
** CID 1256091:  Uninitialized value use  (UNINIT)
/raster/r.colors/edit_colors.c: 315 in edit_colors()
/raster/r.colors/edit_colors.c: 319 in edit_colors()
/raster/r.colors/edit_colors.c: 270 in edit_colors()
/raster/r.colors/edit_colors.c: 289 in edit_colors()
/raster/r.colors/edit_colors.c: 335 in edit_colors()
/raster/r.colors/edit_colors.c: 269 in edit_colors()
/raster/r.colors/edit_colors.c: 288 in edit_colors()
/raster/r.colors/edit_colors.c: 268 in edit_colors()
/raster/r.colors/edit_colors.c: 287 in edit_colors()
________________________________________________________________________________________________________
*** CID 1256093:  Resource leak  (RESOURCE_LEAK)
139         Vect_destroy_line_struct(Pline);
140         Vect_destroy_line_struct(Pout);
141         Vect_destroy_cats_struct(Cats);
142         Vect_destroy_cats_struct(Cline);
143         Vect_destroy_cats_struct(Cnew);
144
>>>     Variable "exclude_list" going out of scope leaks the storage it points to.
145         return narcs;
*** CID 1256092:  Uninitialized pointer read  (UNINIT)
797
798                 G_free_tokens(lines);
799                 G_free_tokens(angles);
800             }
801             else {
802                 for (i = 0; i < node->n_lines; i++) {
>>>     Using uninitialized value "res" when calling "PQgetvalue".
803                     node->lines[i] = atoi(PQgetvalue(res, i, 0));
804                     if (strcmp(PQgetvalue(res, i, 1), "s") != 0) {
805                         /* end node */
806                         node->lines[i] *= -1;
807                     }
808                     node->angles[i] = M_PI / 2 -
atof(PQgetvalue(res, i, 2));
*** CID 1256091:  Uninitialized value use  (UNINIT)
309         has_cell_type = 0;
310             for(i = 0; i < input_maps.num; i++) {
311                     name = input_maps.names[i];
312                     mapset = input_maps.mapsets[i];
313
314                     if (type == RASTER3D_TYPE) {
>>>     Using uninitialized value "input_maps.map_types".
315                             input_maps.map_types[i] = 1; /* 3D
raster maps are always floating point */
316                             has_fcell_type = 1;
317                             Rast3d_read_range(name, mapset, &range);
318                     } else {
319                             input_maps.map_types[i] =
Rast_map_is_fp(name, mapset);
320                             if(input_maps.map_types[i] == 1)
313
318                     } else {
321                                     has_fcell_type = 1;
322                             else
323                                     has_cell_type = 1;
324
264         }
265
266         int stat = -1;
267         if (remove) {
268             for(i = 0; i < input_maps.num; i++) {
269                     name = input_maps.names[i];
>>>     Using uninitialized value "input_maps.mapsets".
270                     mapset = input_maps.mapsets[i];
271
272                             if (type == RASTER3D_TYPE) {
273                                     stat = Rast3d_remove_color(name);
274                             } else {
275                                     stat = Rast_remove_colors(name, mapset);
283         }
284
285         G_suppress_warnings(TRUE);
286
287             for(i = 0; i < input_maps.num; i++) {
288                     name = input_maps.names[i];
289                     mapset = input_maps.mapsets[i];
290
291                     if (type == RASTER3D_TYPE) {
292                             have_colors = Rast3d_read_colors(name,
mapset, &colors);
293                     } else {
294                             have_colors = Rast_read_colors(name,
mapset, &colors);
329                             if(has_fcell_type && has_cell_type) {
330                                     G_fatal_error("Input maps must
have the same cell type. "
331                                                     "Mixing of
integer and floating point maps is not supported.");
332                             }
333                     }
334
>>>     Using uninitialized value "input_maps.max".
335                     Rast_get_fp_range_min_max(&range,
&input_maps.min[i], &input_maps.max[i]);
336
337                     /* Compute min, max of all maps*/
338                     if(i == 0) {
339                             min = input_maps.min[i];
340                             max = input_maps.max[i];
331                                                     "Mixing of
332                             }
333                     }
334
>>>     Using uninitialized value "input_maps.min".
336
338                     if(i == 0) {
263                     }
264         }
265
266         int stat = -1;
267         if (remove) {
>>>     Using uninitialized value "input_maps.names".
271
274                             } else {
282             return EXIT_SUCCESS;
283         }
284
286
290
mapset, &colors);
293                     } else {
262                             G_fatal_error(_("%s map <%s> not
found"), Maptype, input_maps.names[i]);
263                     }
264         }
265
266         int stat = -1;
267         if (remove) {
>>>     Using uninitialized value "input_maps.num".
271
281             }
283         }
284
286
290
mapset, &colors);
To view the defects in Coverity Scan visit,
http://scan.coverity.com/projects/1038?tab=overview
