[GRASS-dev] [GRASS GIS] #2108: default temporal database
GRASS GIS trac at osgeo.org
Tue Nov 25 03:36:36 PST 2014
  Reporter:  lucadelu   |       Owner:  grass-dev@…
      Type:  defect     |      Status:  closed
  Priority:  normal     |   Milestone:  7.0.0
 Component:  Temporal   |     Version:  svn-trunk
Resolution:  duplicate  |    Keywords:  connect
  Platform:  All        |         Cpu:  Unspecified
Changes (by lucadelu):
  * status:  new => closed
  * resolution:  => duplicate
Comment:
 Replying to [comment:2 huhabla]:
 > The reason to put the temporal database by default in the PERMANENT
 mapset is an ongoing discussion in ticket #2110.
 Also this ticket #2258 is speaking of the same problem
 > However, the temporal database should not be placed in the same folder
 as the vector attribute database [1].
 > [1] http://lists.osgeo.org/pipermail/grass-dev/2012-December/061138.html
 I'm going to close this ticket, follow the discussion in the other
 tickets.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2108#comment:3>
