#2343: GRASS 7: "inf" values break insert statements in v.rast.stats
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python | Version: svn-releasebranch70
Keywords: v.rast.stats | Platform: All
Cpu: All |
Comment(by lucadelu):
Replying to [comment:5 sbl]:
> Replying to [comment:4 lucadelu]:
> > Could you provide a dataset to test the patches?
> You can reproduce the issue with these commands:
> g.region -p n=1 s=0 e=2 w=0 res=1
> r.mapcalc --o expression="rastermap1=1"
> r.mapcalc --o expression="rastermap2=double(if(x()==0.5,-1,1))"
> r.to.vect --o --v input=rastermap1 output=vectormap type=area
> v.rast.stats -c --verbose map=vectormap raster=rastermap2
column_prefix=value
In r62938 I should fixed the error.
I change a little bit your patch to cover multiple way to catch Infinity
value.
If it is working I'll backport the changeset to GRASS70.
I also applied your patch for GRASS64 version in r62944.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2343#comment:6>
