[GRASS-dev] grass with LASzip
Anna Petrášová
kratochanna at gmail.com
Tue Nov 25 07:18:31 PST 2014
On Tue, Nov 25, 2014 at 9:45 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Nov 25, 2014 at 3:04 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > On Tue, Nov 25, 2014 at 2:54 AM, Luca Delucchi <lucadeluge at gmail.com>
> wrote:
> >> On 25 November 2014 at 02:19, Anna Petrášová <kratochanna at gmail.com>
> > Of course I recompiled libLAS and I did specify where to look for LASzip,
> > but it doesn't seem to be enough in my case. I assume, you don't have any
> > problems?
> ... works all fine on Fedora:
but where do you have your LASzip binary?
> GRASS 7.0.0svn (patUTM32):/raw_data/las13_format> r.in.lidar
> dati-grezzi001699_WGS.laz out=dati-grezzi001699 -o
> Over-riding projection check
> Reading data ...
> 100%
> Writing to map ...
> 100%
> r.in.lidar complete.
> GRASS 7.0.0svn (patUTM32):/raw_data/las13_format> v.in.lidar
> dati-grezzi001699_WGS.laz out=dati_grezzi001699 -o
> Importing 64549575 points...
> (test from last week).
> There was a similar question in the Italian GRASS ML and I suspect
> that the user is also on Ubuntu.
> You may try "ldd" on the binary.
ldd /usr/local/bin/lasinfo
liblaszip.so.6 =>
/home/anna/dev/LASzip/laszip-src-2.2.0/build/lib/liblaszip.so.6
(0x00007fc425941000)
which is expected.
Anyway, maybe it's my fault, so let's not spend more time on this, and if
it's a real problem, someone will probably run into this later too.
Thanks
Anna
> See for a test file here:
> lasinfo libLAS-1.7.0/test/data/1.2-with-color.laz
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141125/6c1a1251/attachment.html>
