[GRASS-dev] Resolved - Error in GRASS GIS 7.0 database
Erick Opiyo osgis.dev at gmail.com
Tue Nov 25 07:36:17 PST 2014
I have replaced g.mlist with g.list.
And now I have two versions of grass 7.0-r62941 and 7.1-r62932
But, now I get another wired error, shown below: For both 7.0 and 7.1
*7.0*
ERROR: output map <MOD13Q1.h16v05.2000081.EVI.Filtered.tiff> exists
  File "phenology/cloud_filter/grass_modis_filter_MODIS.py", line 72, in
<module>
    R3,R2,R4,R1,R5,E3), overwrite=False)
  File "/usr/local/grass-7.0.0svn/etc/python/grass/script/core.py", line
465, in parse_command
    res = read_command(*args, **kwargs)
425, in read_command
    return handle_errors(returncode, stdout, args, kwargs)
308, in handle_errors
    returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['r.mapcalc',
'expression=.......some long expression.....)'] ended with error
Process ended with non-zero return code 1. See errors in the (error) output.
*Note: *The line 72 in the file grass_modis_filter_MODIS.py starts with
g.parse_command("r.mapcalc", expression=.....
*7.1*
<module>
  File "/usr/local/grass-7.1.svn/etc/python/grass/script/core.py", line
Thanks
Erick
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141125/ca02cfff/attachment.html>
