[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Tue Nov 25 12:49:13 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:30 glynn]:
> Replying to [comment:27 annakrat]:
> > I will change r.colors options (raster -> rast, volume -> rast3d)
unless someone is against, sometime soon.
> "raster" shouldn't be abbreviated. "volume" should probably be
"raster_3d" (for which "raster3d" and "rast3d" are accepted
abbreviations).
So we then have to rename also option rast, rast3d in g.region I suppose,
and perhaps some others. We shouldn't forget that although unabbreviating
doesn't cause problems in the command line, python scripts require the
full name of the command.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:32>
