[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Tue Nov 25 14:10:16 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:32 annakrat]:
> Replying to [comment:30 glynn]:
> > Replying to [comment:27 annakrat]:
> > > I will change r.colors options (raster -> rast, volume -> rast3d)
unless someone is against, sometime soon.
> > "raster" shouldn't be abbreviated. "volume" should probably be
"raster_3d" (for which "raster3d" and "rast3d" are accepted
abbreviations).
> So we then have to rename also option rast, rast3d in g.region I
suppose, and perhaps some others. We shouldn't forget that although
unabbreviating doesn't cause problems in the command line, python scripts
require the full name of the command.
I would not unabbreviate everything. Some standard widely used
abbreviations such as `rast` or `vect` are OK I would say. Non-abbreviated
terms should be used for less standard things such as `elevation` or
`index`. This is a good compromise between clear readable names and overly
long options and module calls.
Of course in some cases unabbreviating would be quite harmless concerning
total length of option(s), for example `rast` -> `raster` but I don't have
an idea how badly this would work for `strds` (which I'm not comfortable
with but I don't have a better idea).
Also sometimes you just have to make the option name shorter by leaving
out some words. Of course this is combined a lot with abbreviating because
it would be not readable anyway, for example `npmin` from G7:v.surf.rst
which has meaning ''Minimum number of points for approximation in a
segment'', the only meaningful not shortened not abbreviated name I can
think of is `minimum_of_points_for_approximation` which is juts too long.
This brings me to my final point. If we unabbreviate and unshorten
everything and we will provide a lot of different options how to
abbreviate it then we can naturally expect that people will use it a lot
and they will of course use different abbreviations. But this, I think,
defeats the purpose of unabbreviated option that is readability (and auto-
documentation) because by looking at the command with abbreviated option
you are not able to say what they mean.
Therefore, I think that using the abbreviations occasionally on places
where everybody would like to shorten anyway is the way to go.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:34>
