[GRASS-dev] Export of integer raster from GRASS 70 with raster attribute table shifts classes
Markus Metz
markus.metz.giswork at gmail.com
Wed Nov 26 01:17:41 PST 2014
Newcomb, Doug wrote:
> Hi Folks,
> I was running r.geomorphon,
> http://grass.osgeo.org/grass70/manuals/addons/r.geomorphon.html, to generate
> a landscape integer grid. I decided to share the output with a colleague
> running ArcGIS. I exported with the raster attribute table option to HFA (
> img , int16 ) format and passed it along. He noticed something in the
> attribute table that was a bit odd.
> The the output values for r.geomorphon are integer values from 1 -10 . The
> output .img file
> had the following in the following output for gdalinfo ( see below)
> As you can see below, a 0 value was added to the color table and the
> class_names start at 0 and not at 1 ( i.e, flat=0, but flat should equal 1)
> . The pixel values do not change, the class names in the
> GDALRasterAttributeTable are are associated with a lower pixel value
> (shifted down one value.1--->0 and so on)
the fields in the attribute table as reported by GDAL are
Red, Green, Blue, Opacity, min, max, Class_Names
the first entry is
0, 0, 0, 0, 1, 1, flat
the pixel value 1 has the correct label "flat", but the color rule is wrong.
Looking at the Color Table (RGB with 11 entries) as reported by GDAL,
the first two entries are
0: 0,0,0,0
1: 220,220,220,255
this is correct, but different from the attribute table reported by
GDAL. The attribute table has thus correct labels but wrong colors.
The attribute table as created by GRASS contains in this case only
pixel values and labels, because it difficult to merge labels and
color rules. In GRASS, color rules and category labels are completely
separate, you can e.g. have 10 labels and 20 color rules. GDAL failed
to merge labels and color rules.
Markus M
> Exporting via r.out.gdal to the same file format without a raster attribute
> table or a color table gave a raster with values of 1-10.
> running gdal 1.11.1 on ubuntu 12.04 with GRASS 7.0 snapshot 2014_10_25.
> Not sure if it's a grass or gdal issue
> gdalinfo output:
> Driver: HFA/Erdas Imagine Images (.img)
> Files: NED_SoApp_forms_cell25.img
> NED_SoApp_forms_cell25.img.aux.xml
> Size is 22854, 12004
> Coordinate System is:
> GEOGCS["GCS_WGS_1984",
> DATUM["WGS_1984",
> SPHEROID["WGS_84",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.017453292519943295]]
> Origin = (-86.094722219722215,37.848055555000002)
> Pixel Size = (0.000277777777802,-0.000277777777801)
> Corner Coordinates:
> Upper Left ( -86.0947222, 37.8480556) ( 86d 5'41.00"W, 37d50'53.00"N)
> Lower Left ( -86.0947222, 34.5136111) ( 86d 5'41.00"W, 34d30'49.00"N)
> Upper Right ( -79.7463889, 37.8480556) ( 79d44'47.00"W, 37d50'53.00"N)
> Lower Right ( -79.7463889, 34.5136111) ( 79d44'47.00"W, 34d30'49.00"N)
> Center ( -82.9205556, 36.1808333) ( 82d55'14.00"W, 36d10'51.00"N)
> Band 1 Block=64x64 Type=Int16, ColorInterp=Palette
> Description = Layer_1
> NoData Value=-32768
> Metadata:
> COLOR_TABLE_RULE_RGB_0=1.000000e+00 1.000000e+00 220 220 220 220 220 220
> COLOR_TABLE_RULE_RGB_10=1.100000e+01 1.100000e+01 255 0 255 255 0 255
> COLOR_TABLE_RULE_RGB_1=2.000000e+00 2.000000e+00 56 0 0 56 0 0
> COLOR_TABLE_RULE_RGB_2=3.000000e+00 3.000000e+00 200 0 0 200 0 0
> COLOR_TABLE_RULE_RGB_3=4.000000e+00 4.000000e+00 255 80 20 255 80 20
> COLOR_TABLE_RULE_RGB_4=5.000000e+00 5.000000e+00 250 210 60 250 210 60
> COLOR_TABLE_RULE_RGB_5=6.000000e+00 6.000000e+00 255 255 60 255 255 60
> COLOR_TABLE_RULE_RGB_6=7.000000e+00 7.000000e+00 180 230 20 180 230 20
> COLOR_TABLE_RULE_RGB_7=8.000000e+00 8.000000e+00 60 250 150 60 250 150
> COLOR_TABLE_RULE_RGB_8=9.000000e+00 9.000000e+00 0 0 255 0 0 255
> COLOR_TABLE_RULE_RGB_9=1.000000e+01 1.000000e+01 0 0 56 0 0 56
> COLOR_TABLE_RULES_COUNT=11
> Generated_with=GRASS GIS 7.0.0svn
> LAYER_TYPE=athematic
> Image Structure Metadata:
> COMPRESSION=RLE
> 0: 0,0,0,0
> 1: 220,220,220,255
> 2: 56,0,0,255
> 3: 200,0,0,255
> 4: 255,80,20,255
> 5: 250,210,60,255
> 6: 255,255,60,255
> 7: 180,230,20,255
> 8: 60,250,150,255
> 9: 0,0,255,255
> 10: 0,0,56,255
> <GDALRasterAttributeTable Row0Min="0" BinSize="1">
> <FieldDefn index="0">
> <Name>Red</Name>
> <Type>0</Type>
> <Usage>6</Usage>
> </FieldDefn>
> <FieldDefn index="1">
> <Name>Green</Name>
> <Type>0</Type>
> <Usage>7</Usage>
> </FieldDefn>
> <FieldDefn index="2">
> <Name>Blue</Name>
> <Type>0</Type>
> <Usage>8</Usage>
> </FieldDefn>
> <FieldDefn index="3">
> <Name>Opacity</Name>
> <Type>0</Type>
> <Usage>9</Usage>
> </FieldDefn>
> <FieldDefn index="4">
> <Name>min</Name>
> <Type>0</Type>
> <Usage>0</Usage>
> </FieldDefn>
> <FieldDefn index="5">
> <Name>max</Name>
> <Type>0</Type>
> <Usage>0</Usage>
> </FieldDefn>
> <FieldDefn index="6">
> <Name>Class_Names</Name>
> <Type>2</Type>
> <Usage>2</Usage>
> </FieldDefn>
> <Row index="0">
> <F>0</F>
> <F>0</F>
> <F>0</F>
> <F>0</F>
> <F>1</F>
> <F>1</F>
> <F>flat</F>
> </Row>
> <Row index="1">
> <F>220</F>
> <F>220</F>
> <F>220</F>
> <F>255</F>
> <F>2</F>
> <F>2</F>
> <F>summit</F>
> </Row>
> <Row index="2">
> <F>56</F>
> <F>0</F>
> <F>0</F>
> <F>255</F>
> <F>3</F>
> <F>3</F>
> <F>ridge</F>
> </Row>
> <Row index="3">
> <F>200</F>
> <F>0</F>
> <F>0</F>
> <F>255</F>
> <F>4</F>
> <F>4</F>
> <F>shoulder</F>
> </Row>
> <Row index="4">
> <F>255</F>
> <F>80</F>
> <F>20</F>
> <F>255</F>
> <F>5</F>
> <F>5</F>
> <F>spur</F>
> </Row>
> <Row index="5">
> <F>250</F>
> <F>210</F>
> <F>60</F>
> <F>255</F>
> <F>6</F>
> <F>6</F>
> <F>slope</F>
> </Row>
> <Row index="6">
> <F>255</F>
> <F>255</F>
> <F>60</F>
> <F>255</F>
> <F>7</F>
> <F>7</F>
> <F>hollow</F>
> </Row>
> <Row index="7">
> <F>180</F>
> <F>230</F>
> <F>20</F>
> <F>255</F>
> <F>8</F>
> <F>8</F>
> <F>footslope</F>
> </Row>
> <Row index="8">
> <F>60</F>
> <F>250</F>
> <F>150</F>
> <F>255</F>
> <F>9</F>
> <F>9</F>
> <F>valley</F>
> </Row>
> <Row index="9">
> <F>0</F>
> <F>0</F>
> <F>255</F>
> <F>255</F>
> <F>10</F>
> <F>10</F>
> <F>depression</F>
> </Row>
> <Row index="10">
> <F>0</F>
> <F>0</F>
> <F>56</F>
> <F>255</F>
> <F>11</F>
> <F>11</F>
> <F>ERROR</F>
> </Row>
> </GDALRasterAttributeTable>
> Doug Newcomb
> USFWS
> Raleigh, NC
> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> The opinions I express are my own and are not representative of the official
> policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life
> is too short for undocumented, proprietary data formats.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
