[GRASS-dev] [GRASS GIS] #2476: vector digitizer crashing with _breakLineAtIntersection
trac at osgeo.org
Wed Nov 26 07:38:03 PST 2014
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: vdigit | Platform: Linux
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:1 mmetz]:
> Replying to [ticket:2476 annakrat]:
> > Crashing happens in
[http://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/level_two.c#L356
level_two.c] in wxdigit.py in _addFeature. Without the line, the area
closes without problem, so maybe _breakLineAtIntersection is where
something goes wrong.
> The problem is in
[https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/vdigit/wxdigit.py#L1772
wxdigit.py] in _addFeature: the line is broken, afterwards the digitizer
tries to get the areas for this line. But this line no longer exists
because it has been broken into new lines -> crash.
> You would need to get areas on each side before breaking the line, but
the vector lib might only be able to build areas after the new line was
broken. I would suggest to break the line only after trying to attach
centroids.
Fixed in r63077.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2476#comment:2>
