[GRASS-dev] planning grass 7.0.0beta4
Anna Petrášová kratochanna at gmail.com
Wed Nov 26 07:38:59 PST 2014
On Wed, Nov 26, 2014 at 8:48 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 26/11/14 14:33, Markus Neteler wrote:
>> On Sun, Nov 23, 2014 at 12:54 AM, Sören Gebbert
>> <soerengebbert at googlemail.com> wrote:
>>> Backport done in r62858 - r62867.
>>> I hope everything works fine.
>> Great, thanks for your efforts!
>>  It would be great if we could automatically test all the changes that
>>> i have introduced in the release branch using the testsuite.
>> Do you mean "online" on a server?
>>  A "make distclean" is needed.
>> Martin is currently going through the parameters for
>> http://trac.osgeo.org/grass/ticket/2409
>> Then we might be ready for beta4 by end of this week.
> I still think that #2439 (and its duplicate #2476) is an almost blocker.
> Digitization is a fundamental tool and these crashes render it almost
> unusable for the normal(uninformed) user.
> Anyone out there with sufficient knowlege of GUI and vector code to check
> this ?
I tried but failed, I don't understand the vector library structures
enough. As far as I remember, I identified the place where it crashes, if
that helps. So probably either Martin or Markus Metz would be able to fix
it.
Anna
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141126/effd8854/attachment.html>
