[GRASS-dev] [GRASS GIS] #2501: r.out.gdal -t creates offset values in raster table for integer grids with values beginning with 1
trac at osgeo.org
Wed Nov 26 11:01:07 PST 2014
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-releasebranch70
Keywords: r.out.gdal table attribute alignment | Platform: Linux
Cpu: x86-64 |
Exporting integer grids with values starting with 1 using r.out.gdal -t
results in a raster attribute table with vertically shifted values in the
last 3 columns.
For example, if you have a raster with values of 1 to 5 with associated
classes, you would expect a table that looks like this:
OID Value MIN MAX CLASS
1 1 1 1 flat
2 2 2 2 summit
3 3 3 3 ridge
4 4 4 4 shoulder
5 5 5 5 spur
( Should the OID start with 0?, not sure )
In the current version of the software, the output table looks like this:
0 0 1 1 flat
1 1 2 2 summit
2 2 3 3 ridge
3 3 4 4 shoulder
4 4 5 5 spur
5 5 0 0 ERROR
See http://lists.osgeo.org/pipermail/grass-dev/2014-November/072021.html,
The issue seems to be in lines 73 - 78 in r.out.gdal/attr.c:
if (maptype == CELL_TYPE) {
for (i = 0; i < cats.ncats; i++) {
label = Rast_get_ith_c_cat(&cats, i, &CellMin, &CellMax);
GDALRATSetValueAsInt(hrat, i, 0, CellMin);
GDALRATSetValueAsInt(hrat, i, 1, CellMax);
GDALRATSetValueAsString(hrat, i, 2, label);
With this current ugly hack I've got has the values aligned with the
classes again, but there is an extra OID 0 line with 0 or blank values for
the fields at the beginning of the table.
for (i = 0; i < cats.ncats-1; i++) {
GDALRATSetValueAsInt(hrat, i+1, 0, CellMin);
GDALRATSetValueAsInt(hrat, i+1, 1, CellMax);
GDALRATSetValueAsString(hrat, i+1, 2, label);
Sample output to this hack would be:
0 0 0 0
1 1 1 1 flat
2 2 2 2 summit
3 3 3 3 ridge
4 4 4 4 shoulder
5 5 5 5 spur
This does not look quite right.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2501>
