[GRASS-dev] temporal framework currently not working on windows
Anna Petrášová
kratochanna at gmail.com
Wed Nov 26 12:15:20 PST 2014
I just realized temporal framework doesn't work with recent GRASS 70
version on Windows:
t.list or t.create give me:
File "<string>", line 1, in <module>
File "C:\GRASS70\GRASS GIS
7.0.0svn\Python27\lib\multiprocessing\forking.py", line 380,
in main
prepare(preparation_data)
7.0.0svn\Python27\lib\multiprocessing\forking.py", line 495,
in prepare
'__parents_main__', file, path_name, etc
File "C:\GRASS70\GRASS GIS 7.0.0svn\scripts\t.create.py",
line 60, in <module>
import grass.temporal as tgis
7.0.0svn\etc\python\grass\temporal\__init__.py", line 29, in
<module>
from temporal_vector_algebra import *
File "C:\GRASS70\GRASS GIS 7.0.0svn\etc\python\grass\tempo
ral\temporal_vector_algebra.py", line 422, in <module>
import grass.pygrass.modules as pygrass
7.0.0svn\etc\python\grass\pygrass\modules\__init__.py", line
2, in <module>
from grass.pygrass.modules.interface import Module,
ParallelModuleQueue
File "C:\GRASS70\GRASS GIS 7.0.0svn\etc\python\grass\pygra
ss\modules\interface\__init__.py", line 9, in <module>
from grass.pygrass.modules.interface import module
ss\modules\interface\module.py", line 188, in <module>
class Module(object):
ss\modules\interface\module.py", line 591, in Module
@mdebug(1, extra=_get_bash)
ss\modules\interface\module.py", line 36, in mdebug
msgr = get_msgr()
7.0.0svn\etc\python\grass\pygrass\messages\__init__.py",
line 352, in get_msgr
_instance[0] = Messenger(*args, **kwargs)
line 175, in __init__
self.start_server()
line 185, in start_server
self.server.start()
7.0.0svn\Python27\lib\multiprocessing\process.py", line 130,
in start
self._popen = Popen(self)
7.0.0svn\Python27\lib\multiprocessing\forking.py", line 258,
in __init__
cmd = get_command_line() + [rhandle]
7.0.0svn\Python27\lib\multiprocessing\forking.py", line 358,
in get_command_line
is not going to be frozen to produce a Windows
executable.''')
RuntimeError:
Attempt to start a new process before the
current process
has finished its bootstrapping phase.
This probably means that you are on Windows and
you have
forgotten to use the proper idiom in the main
module:
if __name__ == '__main__':
freeze_support()
The "freeze_support()" line can be omitted if
the program
executable.
I tested with the most recent build and a user reports the same problem
with r62706.
Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141126/394703f9/attachment-0001.html>
