[GRASS-dev] sample vector temporal data
Luca Delucchi lucadeluge at gmail.com
Wed Nov 26 13:30:49 PST 2014
On 26 November 2014 at 20:22, Anna Petrášová <kratochanna at gmail.com> wrote:
> yes, but there are no NC towns as points in the standard dataset. You could
> use  precip_30ynormals at PERMANENT which are the meteorology stations, which
> probably doesn't make much sense since but maybe it's still good for the
> dataset.
Ok, I saw them
> Helena suggests here to select a smaller, dynamic area (some cape for
> example) and also provide a DEM and ortho for that area (elev_lid792 is not
> coastal) to get some context. I am not sure about this dataset, if it's
> really needed, because I don't know what kind of temporal vector analysis we
> could show in the manual. It could be a good dataset to show how to create
> animations. If we decide to do it, I can help you with this part.
> Another option is to derive contours from the temperature/precipitation
> dataset. The advantage is that's easier to prepare.
as you prefer, for me it is the same...
> Anna
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
