[GRASS-dev] temporal framework currently not working on windows
    Martin Landa
    landa.martin at gmail.com
    Thu Nov 27 02:42:10 PST 2014
2014-11-26 21:15 GMT+01:00 Anna Petrášová <kratochanna at gmail.com>:
> I just realized temporal framework doesn't work with recent GRASS 70 version
> on Windows:
> t.list or t.create give me:
>   File "C:\GRASS70\GRASS GIS
> 7.0.0svn\Python27\lib\multiprocessing\forking.py", line 258,
> in __init__
>     cmd = get_command_line() + [rhandle]
> 7.0.0svn\Python27\lib\multiprocessing\forking.py", line 358,
> in get_command_line
>     is not going to be frozen to produce a Windows
> executable.''')
> RuntimeError:
>             Attempt to start a new process before the
> current process
>             has finished its bootstrapping phase.
>             This probably means that you are on Windows and
> you have
>             forgotten to use the proper idiom in the main
> module:
>                 if __name__ == '__main__':
>                     freeze_support()
>             The "freeze_support()" line can be omitted if
> the program
> executable.
see also [1].
Martin
[1] http://trac.osgeo.org/grass/ticket/580#comment:60
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
