[GRASS-dev] test scripts in the path
Sören Gebbert soerengebbert at googlemail.com
Thu Nov 27 05:02:18 PST 2014
These are binaries and needed for testing purposes. They are called by
gunittest Python scripts, so they need to be in the module path. They
are build by default, but surely can be removed from Windows or Linux
package/distributions.
An other approach would be to add test build to the Makefile system,
so that "make test" will build all test binaries? But i have no time
to integrate such an approach.
Best regards
Soeren
2014-11-26 17:07 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
> Hi,
> is it need to have such script in the path?
> test.r3flow        test.raster3d.lib
> Martin
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.eu/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
