[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Thu Nov 27 08:32:33 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:52 martinl]:
> Replying to [comment:51 wenzeslaus]:
> > > shortly saying I don't see any problem to name the element as
'volume' and use "3D raster map" in the manual and as element
description..
To me, this sounds like a possible source of confusion.
> > I do.
> Anyone else has so clear idea about that?
It seems that the only reason why you want 'volume' is to enable typing
'g.list rast', which isn't enough for me. If we wouldn't change rast to
raster, there would be no need to change rast3d to volume. So in my view
we ended up with something worse then we had before just because we
started to unabbreviate everything. I thought the initial idea was to fix
only apparently bad parameter names, but this is starting to have large
consequences - changes in scripts, manual pages, and confusing users.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:53>
