[GRASS-dev] check on GRASS revision number
Michael Barton
Michael.Barton at asu.edu
Fri Nov 28 14:25:59 PST 2014
Markus explained that this is for libgis only. That seems OK to me. My concern (based on the error message generated) is that this would block any module built against any version older than the current one being run. That seemed an unnecessarily strong check, but apparently not what is happening.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Nov 27, 2014, at 10:40 AM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>> Why do we need to do this?
> Because getting developers to agree to maintaining a stable ABI (then
> ensuring that actually happens) appears to be beyond our capabilities.
> Probably the most common (and certainly the most obvious) example of
> incompatible changes (and the trigger for adding that check in the
> first place) is adding new enumerants in the middle of "enum STD_OPT"
> (the constants passed to G_define_standard_option()), resulting in all
> subsequent enumerants getting new values, resulting in the module
> suddenly accepting completely different (and usually completely
> nonsensical) options.
