[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
Anna Petrášová kratochanna at gmail.com
Sat Nov 29 14:09:29 PST 2014
On Sat, Nov 29, 2014 at 4:58 PM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Anna Petrášová wrote:
> > What about r.stats using uppercase flags:
> > -A Print averaged values instead of intervals (floating-point maps only)
> > -N Do not report cells where all maps have no data
> > -C Report for cats floating-point ranges (floating-point maps only)
> This isn't so much of an issue. As flags are limited to a single
> character, there are fewer choices available. Modules with many flags,
> would end up having to use almost entirely arbitrary flag names once
> the first, second, third, ... choices were already taken.
Ok then. We should probably try to avoid too many flags in the first place.
Thanks
Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141129/67633d1d/attachment.html>
