[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Sun Nov 30 13:31:21 PST 2014
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by annakrat):
 Replying to [comment:76 cmbarton]:
 > Could it cause a problem somewhere down the line to have this term
 beginning with a number--e.g. If it is used to name a temp file or
 something?
 As I already said, it causes problems for Python because keyword parameter
 can't start with number. This is solvable by adding underscore and some
 special handling of this case, which is partially there already. It
 violates pep8.
 Otherwise, I am not sure if we can expect some problems with temporal
 database with 3D raster time series. If the column names stay as they are
 now, it shouldn't be problem I think?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:77>
