[GRASS-dev] [GRASS GIS] #2439: g.gui.iclass crashes
trac at osgeo.org
Wed Oct 1 07:43:41 PDT 2014
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.iclass, classification, imagery | Platform: Linux
Cpu: x86-64 |
Comment(by madi):
Replying to [comment:3 annakrat]:
> Does vector digitizer works for you, can you digitize areas?
Yes it works (although the digitizer somehow "retains" the cursor from the
terminal even after closing it, thus, before doing anything else in the
terminal, I have to ctrl+c to get back my cursor).
> g.gui.iclass is using it. Is there any specific number of polygons you
manage to digitize before it crashes or it changes every time?
I managed to digitize up to 3 small polygons. Trials were uniformly
distributed between (1,3).
Since I verified that the digitizer works standalone, I have created the
training map separately and then launched the g.gui.iclass from command
line passing it. It doesn't seem to work though, the histograms are empty,
coincident plots are horizontal lines and "scatter plots" only shows the
grey empty area that is probably supposed to lie beneath the graphs.
I understand that this problems are nearly impossible to reproduce on
other machines. I'll try with my laptop to see if it works there.
Thank you for your time
Ticket URL: <http://trac.osgeo.org/grass/ticket/2439#comment:4>
