[GRASS-dev] Issues with Sphinx on osgeo server
    Sören Gebbert
    soerengebbert at googlemail.com
    Sat Oct  4 14:53:24 PDT 2014
i have the same problem on Ubuntu 12.04. The documentation for the
wxgui failed to build with a shell error.
As a workaround (and to save time building the library docs) i added
"make sphinxdoclib" to the GRASS make system, so that only the python
library documentation is build. This includes the source code
documentation as well.
The documentation at:
http://grass.osgeo.org/grass71/manuals/libpython/
lacks the source code doc links in the library documentation which are
important.
Hopefully will "make sphinxdoclib" fix this on the server.
Best regards
Soeren
2014-10-04 23:32 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> On Sat, Oct 4, 2014 at 10:31 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> # generate pyGRASS sphinx manual (in docs/html/libpython/)
>> (cd lib/python/docs/ ; make libpythonhtml)
>> --> works ok
>> # generate wxGUI sphinx manual etc, (in main src directory)
>> make sphinxdoc
>> --> fails (also on Fedora):
> I have updated the cronjob and continue to use
> The sphinx based docs are back now:
> - PyGRASS documentation
> - The GRASS GIS Temporal Framework
> - Testing GRASS GIS source code and modules
> cheers
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
