[GRASS-dev] python2/3 and GRASS build on Arch
Maciej Sieczka
msieczka at sieczka.org
Sun Oct 5 06:44:49 PDT 2014
W dniu 04.01.2013 o 00:13, Glynn Clements pisze:
> Maciej Sieczka wrote:
>>> The python interpreter is accessed via the make variable PYTHON, so
>>> you can use e.g.:
>>> make PYTHON=python2
>> Still one error crops out - ctypesgen.py has "#!/usr/bin/env python"
>> shebang, which calls Python 3.x on Arch, therefore:
>> Changing that shebang to python2 let the build complete OK. Do you know
>> if there is a workaround which does not involve modyfying the source though?
> Create a directory containing a symlink from "python" to the python2
> executable, than add that directory to the front of the PATH.
I have successfully aplied this approach (symlink `python2' in the root
of releasebranch_7_0 working copy as `python', add that dir to the front
of the PATH, export PATH, run `make') until recently I started getting
the following error during build:
$ pwd
/home/pok/aur/grass70-svn/src/grass70-svn/gui/wxpython/iclass
$ make
make
/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/docs/html/g.gui.iclass.html
make[1]: Entering directory
'/home/pok/aur/grass70-svn/src/grass70-svn/gui/wxpython/iclass'
GISRC=/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70
GISBASE=/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu
PATH="/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/bin:/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/bin:/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/scripts:$PATH"
PYTHONPATH="/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/etc/python:/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/bin:/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/scripts:/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/lib:/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/lib:"
LC_ALL=C
/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/scripts/g.gui.iclass
--html-description < /dev/null | grep -v '</body>\|</html>' >
g.gui.iclass.tmp.html
File
"/home/pok/aur/grass70-svn/src/grass70-svn/dist.x86_64-unknown-linux-gnu/scripts/g.gui.iclass",
line 54, in <module>
import wx
ImportError: No module named 'wx'
../../../include/Make/GuiScript.make:36: recipe for target
'g.gui.iclass.tmp.html' failed
make[1]: *** [g.gui.iclass.tmp.html] Error 1
rm g.gui.iclass.tmp.html
make[1]: Leaving directory
../../../include/Make/GuiScript.make:22: recipe for target 'guiscript'
failed
make: *** [guiscript] Error 2
I can `import wx' without issue on `python2' shell, but not on `python3'
shell, so it seems to me the error above is due to Python 3 being used
instead of Python 2, in spite of the symlink "hack".
Every other GRASS 7 Python thing builds fine though. Why is iclass build
trying to use Python 3? How should deal with this, the least intrusive way?
Maciek
Maciej Sieczka
http://www.sieczka.org
