[GRASS-dev] [GRASS GIS] #2441: Underscore to avoid Python keywords used improperly in grass.script
GRASS GIS trac at osgeo.org
Sun Oct 5 19:23:54 PDT 2014
 Reporter:  wenzeslaus                     |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  normal                         |   Milestone:  7.0.0
Component:  Default                        |     Version:  svn-trunk
 Keywords:  PEP8, python keywords, parser  |    Platform:  Unspecified
      Cpu:  Unspecified                    |
Comment(by wenzeslaus):
 Replying to [comment:1 glynn]:
 > No objections, although `opt = opt.strip('_')` would probably suffice.
 GRASS option names will never start or end with an underscore.
 I will strip just one at the begging or one at the end. I don't want
 people to use `__lambda__` or something like this.
 I even consider to write to doc that `_lambda` is obsolete (in 7.0) and in
 next versions (7.1 or 7.5) I would include a warning. Finally, I would
 remove (7.2 or 8.0) the condition completely. This would allow for GRASS
 option names starting with underscore which might be used for some
 internal purpose (although this is probably not a good idea).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2441#comment:2>
