#2437: order parameters in g.remove window
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: unspecified
Keywords: g.remove | Platform: All
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:2 hcho]:
> I think that the current order makes it easier to implement a list of
maps drop down. It's better to restrict map types first and then search
for and list related maps in the drop down. Since we moved away from
single option per map type, we may need some trick in the GUI.
done in r62191, testing is welcome of course.
The order - type, pattern - makes sense. I removed some unused types
(#2440) so the pattern is now hopefully visible without scrolling. So we
might perhaps close this ticket after testing and backporting.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2437#comment:3>
