[GRASS-dev] [GRASS GIS] #1239: wxGUI command layer broken and unusable
trac at osgeo.org
Sun Oct 5 21:38:48 PDT 2014
Reporter: garu | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.3 RCs
Resolution: fixed | Keywords: layer manager
Platform: MSWindows XP | Cpu: Unspecified
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
Since the most important parts of the ticket were fixed, closing the
ticket.
The remaining points does not fit the summary/title, are from different
category, have very different priority, are probably wontfix, and in any
case should be tracked separately. Please create new tickets with fresh
description of the problem, screenshots and suggestions. It would be
actually useful to identify problems with the layer tree in Layer Manager.
2) Even when setting the height to 40 if the entered command exceeds the
horizontal visible
space, the horizontal scroll bar has no effect. To scroll you have to put
the caret into the
text box and scroll back and forth using the arrow keys.
5) Since when the text box is initially created, the visible width is set
relative to the width
of the Layer Manager panel, one would expect that resizing the width of
would also resize accordingly the visible part of the text box, but this
does not happen.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1239#comment:15>
