[GRASS-dev] [GRASS GIS] #1820: WinGRASS -- Multiple Map Display Lockup?
trac at osgeo.org
Sun Oct 5 21:57:23 PDT 2014
Reporter: ianhawboldt | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: unspecified
Resolution: fixed | Keywords: workspace
Platform: MSWindows XP | Cpu: x86-32
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:4 ianhawboldt]:
> The WindowsXP version of WinGRASS 6.4.3-svn-r54192 still can't open a
workspace which defines multiple map display windows. The symptoms remain
unchanged from my original post.
Sorry for a (very) late answer, the fix was in r54219 and probably some
following commits. It seems you tested older r54192. It is possible that
you cannot use the older workspace file and you need to create a new one.
I consider this is fixed now according to comment:3. Please reopen if you
have exactly the same error, or create a new ticket if you have a
different one (although perhaps related).
> I'm not a programmer, but maybe this traceback from the Command Console
tab will help locate the problem:
Yes, traceback is always helpful.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1820#comment:5>
