[GRASS-dev] [GRASS GIS] #2424: PyGRASS does not work when GRASS is invoked from outside
trac at osgeo.org
Sun Oct 5 22:23:01 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python ctypes | Version: svn-trunk
Keywords: installation, pygrass, temporal, scripts | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by zarch):
Replying to [comment:2 wenzeslaus]:
> Another case when I'm hitting this issue is in running tests.
> There is a script which runs the tests. I import form gunittest
> in this test and I don't really need much but in __init__.py
> I import some things to provide and easy access, so whatever
> I want to import, __init__.py gets executed, because pygrass.modules
> are used this executes the pygrass main __init__.py which imports
> some PyGRASS things which depend on ctypes interface and when
> dynamic libraries are not available, this obviously fails.
> This is an example, how simple you may need dynamic libraries.
> Temporal framework Python API is probably the same case.
Since the pygrass.modules does not depend from the ctypes, I think we
could move the modules stuff outside pygrass to remove the depedencies to
ctypes...
The main problem is that I put in pygrass.__init__:
import grass.lib.gis as _libgis
_libgis.G_gisinit('')
Because all the pygrass sub-modules: gis, raster, vector and functions
must have G_gisinit,
If you think that move the pygrass.modules outside pyrass is not a good
idea, I can move the G_gisinit from the main __init__ of pygrass to the
sub-modules.
> Another way how to improve the situation is to use
> empty __init__.py files.
Generally I'm not against to an empty or almost empty init file.
So If you agree on that, I could change it.
This it will change the way as we import stuff, so it wont be possible to
import:
from grass import pygrass
# and then access to the sub-modules
pygrass.modules.Module
For me it is not a problem, generally I import the class that I need on
the top, like:
from grass.pygrass.modules import Module
In any case I think that the pygrass.modules.__init__ should contain at
least:
from grass.pygrass.modules.interface.module import Module,
ParallelModuleQueue
just to make the use of these classes more convenient and to "hide" the
internal structure:
modules/
interface/
module.py
Otherwise it became too verbose.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2424#comment:4>
