[GRASS-dev] r.mapcalc bug on max and min?
Anna Petrášová
kratochanna at gmail.com
Mon Oct 6 05:25:33 PDT 2014
On Mon, Oct 6, 2014 at 4:51 AM, Pietro <peter.zamb at gmail.com> wrote:
> Dear all,
> I would like to rescale a raster map from a -1, 1 interval to 0, 255.
> To make an example I've tried to normalize the elevation map:
> $ r.mapcalc "el = elevation / max(elevation)" --o
> 100%
> $ r.info el
> | Map: el Date: Mon Oct 6 10:29:19
> 2014 |
> | Mapset: user1 Login of Creator: pietro
> | Location: nc_basic_spm_grass7
> | DataBase: /home/pietro/docdat/gis
> | Title: ( el )
> | Timestamp: none
> | Type of Map: raster Number of Categories: 0
> | Data Type: FCELL
> | Rows: 1350
> | Columns: 1500
> | Total Cells: 2025000
> | Projection: Lambert Conformal Conic
> | N: 228500 S: 215000 Res: 10
> | E: 645000 W: 630000 Res: 10
> | Range of data: min = 1 max = 1
> | Data Description:
> | generated by r.mapcalc
> | Comments:
> As you can see the result is a map with all the values that are 1.
> Instead If I execute:
> $ r.mapcalc "el = elevation / 156.3299" --o
> 100%
> $ r.info el
> | Map: el Date: Mon Oct 6 10:31:17
> 2014 |
> | Title: ( el )
> | Timestamp: none
> | Data Type: DCELL
> | Rows: 1350
> | Columns: 1500
> | Range of data: min = 0.355522472489405 max = 0.999999772928615
> | Data Description:
> | Comments:
> Now it si working... do you know why this r.mapcalc expression:
> "el = elevation / max(elevation)" is wrong?
> Now trying to normalize del "el" map:
> $ RAST="el"
> $ NEW_MAX=255.
> $ NEW_MIN=0.
> $ r.mapcalc "s$RAST = int(float($RAST - min($RAST)) / float(max($RAST)
> - min($RAST)) * ($NEW_MAX - $NEW_MIN) + $NEW_MIN)" --o
> 100%
> $ r.info sel
> | Map: sel Date: Mon Oct 6 10:42:42
> 2014 |
> | Title: ( sel )
> | Timestamp: none
> | Data Type: CELL
> | Rows: 1350
> | Columns: 1500
> | Range of data: min = NULL max = NULL
> | Data Description:
> | Comments:
> | int(float(el - min(el)) / float(max(el) - min(el)) * (255 - 0) + 0)
> Again everything is NULL, I'm doing something wrong or it is a bug?
Glynn could perhaps give you some more precise comment, but basically, max
doesn't operate on the entire map but only on the current cell. So for
example, r.macalc "map_max = max(elevation1, elevation2, elevation3)"
creates a map where each cell is the largest value of the corresponding
cells in the 3 elevation maps.
Hope that helps,
Anna
> Best regards
> Pietro
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141006/2309104b/attachment-0001.html>
