[GRASS-dev] [GRASS GIS] #2326: Command functions in grass.script.core miss a correct error reporting
GRASS GIS trac at osgeo.org
Mon Oct 6 08:18:19 PDT 2014
 Reporter:  wenzeslaus          |       Owner:  grass-dev@…
     Type:  enhancement         |      Status:  new
 Priority:  major               |   Milestone:  7.1.0
Component:  Python              |     Version:  svn-trunk
 Keywords:  script, exceptions  |    Platform:  All
      Cpu:  Unspecified         |
Comment(by wenzeslaus):
 Replying to [comment:21 zarch]:
 > So are 255 lines that need to be checked and adapted. 46 lines in
 gunittest, 85 in the temporal framework and 80 in wxpython.
 I did different search in comment:5 with different results. The problem is
 that both the ones which are using return code and which are not must be
 checked.
 > To me it looks feasible, especially if we split the load on 4/5 people.
 > What do you think?
 Split the load is currently the only option but we need almost everybody
 who is currently active to participate.
 It is quite important step and it will reveal a lot of (already present)
 errors which will create a lot of negative feedback, so that's why is
 should be done well.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2326#comment:22>
