[GRASS-dev] [GRASS GIS] #2424: PyGRASS does not work when GRASS is invoked from outside
trac at osgeo.org
Mon Oct 6 09:09:27 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python ctypes | Version: svn-trunk
Keywords: installation, pygrass, temporal, scripts | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:4 zarch]:
> Since the pygrass.modules does not depend from the ctypes, I think we
could move the modules stuff outside pygrass to remove the depedencies to
ctypes...
> The main problem is that I put in `pygrass.__init__`:
import grass.lib.gis as _libgis
_libgis.G_gisinit('')
> Because all the pygrass sub-modules: gis, raster, vector and functions
must have `G_gisinit`,
> If you think that move the pygrass.modules outside pyrass is not a good
idea, I can move the `G_gisinit` from the main `__init__` of pygrass to
the sub-modules.
I cannot comment on `G_gisinit` much but the error is that the DLL is not
found, so I though that it is before the call.
> > Another way how to improve the situation is to use
> > empty `__init__.py` files.
> Generally I'm not against to an empty or almost empty init file.
> So If you agree on that, I could change it.
> This it will change the way as we import stuff, so it wont be possible
to import:
from grass import pygrass
# and then access to the sub-modules
pygrass.modules.Module
> For me it is not a problem, generally I import the class that I need on
the top, like:
from grass.pygrass.modules import Module
This is what I do too, the same for `grass.script`. But `grass.script` is
an example where some things were used for compatibility and changes in
internal structure are expected in the future I would say. But generally,
yes, it seems that it is better to have empty `__init__.py` files.
I'm not sure if it is better to move `pygrass.modules` outside of
`pygrass` or not. I was not thinking about it much. However, it seems that
`pygrass.modules` is really something different from the library
interface. The only connection is that it is new and Pythonic and it was
implemented together. The `ctypes` dependency is quite a big difference.
I'm not sure if there will be something in the future which would
introduce `ctypes` to modules. Perhaps yes, for example some command line
parsing interface using GRASS parser (based on library rather then on
`g.parser`). What would be the name of a standalone package? Just
`grass.modules`?
> In any case I think that the `pygrass.modules.__init__` should contain
at least:
from grass.pygrass.modules.interface.module import Module,
ParallelModuleQueue
> just to make the use of these classes more convenient and to "hide" the
internal structure:
> Otherwise it became too verbose.
I agree, this is really internal and `__init__.py` should be used to hide
it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2424#comment:5>
