On Wed, Oct 8, 2014 at 12:38 PM, Glynn Clements <glynn at gclements.plus.com> wrote: >> do you think could be useful? > > Not really. Just use r.info (or r.univar if you want the min/max for > the current region) and substitute the result into the expression. Yes, I did in this way. Thank you. Pietro
