[GRASS-dev] [GRASS GIS] #2437: order parameters in g.remove window
GRASS GIS trac at osgeo.org
Thu Oct 9 02:20:31 PDT 2014
 Reporter:  pvanbosgeo   |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Default      |     Version:  unspecified
 Keywords:  g.remove     |    Platform:  All
      Cpu:  Unspecified  |
Comment(by annakrat):
 Replying to [comment:6 hcho]:
 > I just noticed two issues with the new g.list/remove GUI map selectors.
 They should not append @ mapset name and should support multiple
 selection.
 I fixed appending the mapset in r62220.
 If it is not in the interface of the module, gui can't know it should be
 multiple. As you wrote earlier, multiple pattern is handled by the module,
 which is the problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2437#comment:7>
