[GRASS-dev] [GRASS GIS] #2437: order parameters in g.remove window
GRASS GIS trac at osgeo.org
Thu Oct 9 03:31:30 PDT 2014
 Reporter:  pvanbosgeo   |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Default      |     Version:  unspecified
 Keywords:  g.remove     |    Platform:  All
      Cpu:  Unspecified  |
Comment(by hcho):
 Replying to [comment:11 hcho]:
 > Replying to [comment:10 hcho]:
 > > Replying to [comment:9 annakrat]:
 > > > Replying to [comment:8 annakrat]:
 > > > > Replying to [comment:7 annakrat]:
 > > > > > Replying to [comment:6 hcho]:
 > > > > > > I just noticed two issues with the new g.list/remove GUI map
 selectors. They should not append @ mapset name and should support
 multiple selection.
 > > > > > I fixed appending the mapset in r62220.
 > > > > Hm, it started to output warnings about illegal character *. Not
 sure what to do about that...
 > > > I will probably have to revert this and do test for this specific
 case in the gui which I wanted to avoid. However, the problem with
 multiple selection is not just problem of the gui, but also pygrass can't
 currently handle it simply because g.list interface breaks rules.
 > > Hmm... One way would be to change the type of pattern=/exclude= to
 multiple and use their {{{answer}}} variable, not {{{answers}}}. The help
 message would be {{{pattern=string[,string,...]}}}, which can be
 misleading because it doesn't take multiple pattern strings, but it only
 takes multiple map names and a single pattern string. But, it works both
 in GUI and command line.
 > If GUI allows for both multiple map selection and manual pattern typing.
 Still the {{{@MAPSET}}} problem needs to be fixed in GUI.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2437#comment:12>
