[GRASS-dev] [GRASS GIS] #1397: Lat/lon compatibility for r.water.outlet
GRASS GIS trac at osgeo.org
Thu Oct 9 10:48:36 PDT 2014
 Reporter:  awickert        |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  6.4.5
Component:  Raster          |     Version:  svn-releasebranch64
 Keywords:  r.water.outlet  |    Platform:  All
      Cpu:  x86-64          |
Changes (by awickert):
  * milestone:  6.4.4 => 6.4.5
Comment:
 Replying to [comment:6 mlennert]:
 > Replying to [comment:4 awickert]:
 > > Yes - looks like you are correct and that I misread when I used
 G_adjust_east_longitude and thought it performed the check; I really
 wanted G_adjust_easting that wraps G_adjust_east_longitude in the lat/lon
 projection check.
 > > Thanks for looking into this!
 > Any reasons for not applying the proposed patch (but using
 G_adjust_easting instead of G_adjust_east_longitude) ?
 > Moritz
 In my case, I'm not a GRASS-dev, so write access was what prevented me
 from doing this! I have now downloaded GRASS 6.4.5svn to incorporate all
 updates to date and have applied and checked this change. I am now working
 to incorporate it into GRASS 7.1.0svn and will open a separate ticket on
 that once I have finished.
 Thanks in advance to whomever looks into (and hopefully accepts!) this
 fix. Files attached.
 Andy Wickert
Ticket URL: <http://trac.osgeo.org/grass/ticket/1397#comment:7>
