[GRASS-dev] [GRASS GIS] #2445: r.mask -r removal not working in GRASS 7.1 svn r.62210
GRASS GIS trac at osgeo.org
Thu Oct 9 14:30:05 PDT 2014
 Reporter:  baharmon     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Raster       |     Version:  svn-trunk
 Keywords:  r.mask       |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by neteler):
 I check on Linux, no problem:
 GRASS 7.1.svn (nc_spm_08_grass7):~ > r.mask zipcodes
 All subsequent raster operations will be limited to the MASK area.
 Removing
 or renaming raster map named 'MASK' will restore raster operations to
 normal.
 [Raster MASK present]
 GRASS 7.1.svn (nc_spm_08_grass7):~ > r.mask -r
 Raster MASK removed
 GRASS 7.1.svn (nc_spm_08_grass7):~ > g.version -g
 version=7.1.svn
 date=2014
 revision=62126M
 build_date=2014-09-28
 build_platform=x86_64-unknown-linux-gnu
 Which operating system are you using? And: what is the error?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2445#comment:2>
