[GRASS-dev] [GRASS GIS] #2445: r.mask -r removal not working in GRASS 7.1 svn r.62210
trac at osgeo.org
Sat Oct 11 04:46:13 PDT 2014
Reporter: baharmon | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: r.mask | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:5 annakrat]:
> Wontfix?
No. If a map is recognised as a mask by `Rast__check_for_auto_masking()`,
then `r.mask -r` should remove it.
On Windows, remove("MASK") will remove a file named "MASK", "mask",
"Mask", "MaSK" or any other variation (you can't have more than one of
those in any given directory).
Does `g.remove type=rast pattern=MASK` remove the file? If not, that's a
bug in g.remove. Indeed, this appears to be the problem.
Looking at source:grass/trunk/lib/gis/ls_filter.c#L151, regcomp() should
probably be using REG_ICASE on Windows (and also on Unix if GISDBASE is on
a case-insensitive filesystem, but that's easier said than done).
IOW, this bug is a consequence of replacing g.remove with g.mremove; the
former doesn't care about case, the latter does.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2445#comment:6>
