[GRASS-dev] Upper case letters for defining columns via v.db.addtable
Johannes Radinger
johannesradinger at gmail.com
Mon Oct 13 00:47:23 PDT 2014
when I want to specify a column in v.db.addtable, all upper case letters in
the column name get converted to lower case. I'm working on GRASS 71
(trunk). Is this an intended behaviour?
v.db.addtable map=myMap table=test layer=3 columns="My_COL INT"
cheers,
/Johannes
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141013/aff1d557/attachment.html>
