[GRASS-dev] [GRASS-SVN] r61255 - grass/trunk/gui/wxpython/core
Vaclav Petras wenzeslaus at gmail.com
Tue Oct 14 19:24:15 PDT 2014
On Mon, Jul 14, 2014 at 3:03 PM, <svn_grass at osgeo.org> wrote:
> Author: wenzeslaus
> Date: 2014-07-14 12:03:34 -0700 (Mon, 14 Jul 2014)
> New Revision: 61255
> Modified:
>    grass/trunk/gui/wxpython/core/utils.py
> Log:
> wxGUI/core: use gray always, sync purple with lib/gis/color_str.c although
> it is probably wrong
> before: depending on dict ordering gray or grey was used, (un)checking
> Transparent in GUI caused switching from gray to grey
> purple: accoring to Wikipedia it is different from violet and was
> correctly defined in the GUI before but this was not the same as in library
> Modified: grass/trunk/gui/wxpython/core/utils.py
> --- grass/trunk/gui/wxpython/core/utils.py      2014-07-14 18:27:46 UTC
> (rev 61254)
> +++ grass/trunk/gui/wxpython/core/utils.py      2014-07-14 19:03:34 UTC
> (rev 61255)
> @@ -945,29 +945,37 @@
>      # update path
>      if addonPath not in os.environ['PATH']:
>          os.environ['PATH'] = addonPath + os.pathsep + os.environ['PATH']
> -# From lib/gis/col_str.c, except purple which is mentioned
> -# there but not given RGB values
> +# predefined colors and their names
> +# must be in sync with lib/gis/color_str.c
>  str2rgb = {'aqua': (100, 128, 255),
>             'black': (0, 0, 0),
>             'blue': (0, 0, 255),
>             'brown': (180, 77, 25),
>             'cyan': (0, 255, 255),
>             'gray': (128, 128, 128),
> +           'grey': (128, 128, 128),
>             'green': (0, 255, 0),
> -           'grey': (128, 128, 128),
>             'indigo': (0, 128, 255),
>             'magenta': (255, 0, 255),
>             'orange': (255, 128, 0),
> -           'purple': (128, 0, 128),
>             'red': (255, 0, 0),
>             'violet': (128, 0, 255),
> +           'purple': (128, 0, 255),
>             'white': (255, 255, 255),
>             'yellow': (255, 255, 0)}
>  rgb2str = {}
> -for (s,r) in str2rgb.items():
> -    rgb2str[ r ] = s
> +for (s, r) in str2rgb.items():
> +    rgb2str[r] = s
> +# ensure that gray value has 'gray' string and not 'grey'
> +rgb2str[str2rgb['gray']] = 'gray'
> +# purple is defined as nickname for violet in lib/gis
> +# (although Wikipedia says that purple is (128, 0, 128))
> +# we will prefer the defined color, not nickname
> +rgb2str[str2rgb['violet']] = 'violet'
> Has somebody some idea about the purple and violet color definitions (in
lib, formerly in GUI, on Wikipedia) before backport to release branch 7.0?
I guess now is the time to change it.
Wikipedia
Violet is (127, 0, 255)
Purple is (128, 0, 128)
http://en.wikipedia.org/wiki/Purple
http://en.wikipedia.org/wiki/Violet_%28color%29
Violet (128, 0, 255)
Purple is the same as Violet (in the same manner as Grey is Gray)
http://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/color_str.c
http://trac.osgeo.org/grass/browser/grass/trunk/include/colors.h
http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/core/utils.py#L948
>  def color_resolve(color):
>      if len(color) > 0 and color[0] in "0123456789":
>          rgb = tuple(map(int, color.split(':')))
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141014/093ed09d/attachment-0001.html>
