[GRASS-dev] [GRASS GIS] #2437: order parameters in g.remove window
GRASS GIS trac at osgeo.org
Sat Oct 18 07:52:32 PDT 2014
 Reporter:  pvanbosgeo                            |       Owner:  grass-dev@…
     Type:  enhancement                           |      Status:  new
 Priority:  normal                                |   Milestone:  7.1.0
Component:  Default                               |     Version:  unspecified
 Keywords:  g.list, g.remove, g.mlist, g.mremove  |    Platform:  All
      Cpu:  Unspecified                           |
Comment(by glynn):
 Replying to [comment:17 annakrat]:
 > In the previous version of g.remove, full name was working. I like the
 previous behavior more but of course the mapset is not really needed.
 Even so, a fully-qualified name should be accepted provided that the
 mapset is the current mapset. Code which executes GRASS modules should be
 able to use fully-qualified names throughout.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2437#comment:18>
