[GRASS-dev] [GRASS GIS] #2437: order parameters in g.remove window
trac at osgeo.org
Mon Oct 20 08:19:47 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: unspecified
Keywords: g.list, g.remove, g.mlist, g.mremove | Platform: All
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:19 hcho]:
> Replying to [comment:18 glynn]:
> > Replying to [comment:17 annakrat]:
> > > In the previous version of g.remove, full name was working. I like
the previous behavior more but of course the mapset is not really needed.
> > Even so, a fully-qualified name should be accepted provided that the
mapset is the current mapset. Code which executes GRASS modules should be
able to use fully-qualified names throughout.
> This behavior is now fixed in r62303.
About "use fully-qualified names throughout" I though that it does not
apply to the output (see also [http://lists.osgeo.org/pipermail/grass-
dev/2014-September/070839.html mailing list], [http://osgeo-
org.1560.x6.nabble.com/v-overlay-handles-mapname-mapset-in-a-wrong-way-
td5162363.html nabble link]). When removing a map, it is of course
questionable if we are executing our write access (as in case of output)
or if we are using existing map (which we can specify with mapset).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2437#comment:20>
