[GRASS-dev] v.in.ogr crashed with SIGSEGV in main() in v.what/test_vwhat_layers
Vaclav Petras
wenzeslaus at gmail.com
Wed Oct 22 17:13:51 PDT 2014
On Wed, Oct 22, 2014 at 4:15 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> Hi,
> 2014-10-22 8:58 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> >> v.in.ogr --q -o dsn=./data/table1.csv output=t1
> > Can you please add
> > db.connect -p
> > to the (local) test?
> just wild guess, could be related to [1]? Martin
> [1] http://trac.osgeo.org/grass/changeset/62325
I though you are fixing it because of that. In fact I was looking at it at
that time but I was so glad that you committed the change because I was not
much successful.
Nevertheless, the test runs now, although I just expected the segmentation
fault to be fixed. (I don't know what caused the test to lead to the
segmentation fault in the first place.)
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-10-22-07-00/report_for_nc_spm_08_grass7_nc/vector/v.what/test_vwhat_layers/index.html
> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141022/7b1a1a6c/attachment.html>
