[GRASS-dev] WinGRASS71svn using Windows shell (not bourne shell) thogh MSYS is installed
Wed Oct 22 17:28:25 PDT 2014
Martin Landa wrote:
> > Given the history of the Python issue I shall not complain about a missing Unix shell on Windows...
> switching to msys shell is easy, just change in env.bat file
> REM set GRASS_SH=%OSGEO4W_ROOT%\apps\msys\bin\sh.exe
> to
> Probably we could add new item to start menu as it's in G6.
Does the Windows installer still contain MSys? If so, why?
