[GRASS-dev] [GRASS GIS] #2272: Improve consistency in random generator usage
GRASS GIS trac at osgeo.org
Fri Oct 24 00:00:52 PDT 2014
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  Default      |     Version:  svn-releasebranch70
 Keywords:  random       |    Platform:  Unspecified
      Cpu:  Unspecified  |
Changes (by neteler):
  * priority:  critical => major
Comment:
 Downgrading priority (or to be closed?).
 Replying to [comment:3 neteler]:
 > For the record, from grass-dev:
 > On Sun, Jul 27, 2014 at 1:58 AM, Glynn Clements wrote:
 > > Cases which haven't been changed are:
 > > lib/raster3d/test/test_put_get_value_large_file.c. This appears to be
 > > a test case; does it matter?
 > > include/iostream/quicksort.h uses random() or rand() to select a pivot
 > > for the quicksort algorithm. That file has no dependency on lib/gis
 > > (or anything else, except for <stdlib.h> for random/rand), and I
 > > didn't want to add one unnecessarily.
 > > Again, this shouldn't affect the result, but there may be performance
 > > issues if the size of the array being sorted is significantly larger
 > > than RAND_MAX (in this situation, the algorithm will be O(n^2) even in
 > > the best case).
 > > Unless there's a specific reason not to, it may be better to simply
 > > replace all uses of that file with std::sort() from <algorithm>.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2272#comment:5>
